1 - 12 of 12 Posts
Electric Tractors
I made a MF10 or MF12g lift rod (the one that goes to the rear lift) it's 1 1/2" or 2" shorter that the Hydra's lift rod and is straight not bent in the middle. 2 90deg bends, 1 at each end, small hole for hair pin, I think it's 1/2 round steel rod, not hard to do.
Electric Tractors
mikebramel said:
oh, ok, thank you very much. i have a 12 rod so i suppose it should be easy to figure out with your info. thanks again!
The one I made, I used a Hydra rod, cut it at the bend, overlapped the 2 to get the right length, and welded them together.
Sold the tractor that rod was on.
Ron Paul
Discussion Starter · #10 ·
thanks, i think i have it figured out. just have to finish the drawing on autocad. will drop the plans and brackets off this or next week. theyre pretty slow so hopefully i can get a good cash price. thanks all
1 - 12 of 12 Posts
