1 - 7 of 7 Posts
I finally got the old rubber off of the 1050. One of the rims has two small spots where it has completely rusted through. Patched it with Por-15 epoxy, which may hold air, it dries very hard. If I do have to replace the rim can someone tell me what size and bolt pattern I need for the rear of a 1966 1050? While you are at it, is there anything special I need to know if I need to replace the fronts?
I have mixed up 12" wheels between brands and have only had trouble a couple of times. I think the rims on one of my Wheelhorses came off of a Bolens. Needed parts like this are why I have a bunch of parts tractors. Good Luck, Rick
Check here http://www.millertire.com/categories/wheels/?sort=featured&page=3. You can order the outer rim as a blank and weld your old center in if need be. Most 5 bolt GT 12" rims are 4.5" on center holes.
Discussion Starter · #5 ·
Thanks Ranier, that is probably what I will do if I can get it cleaned up enough to look decent.
If you go to the miller web site, Scroll down the menu on the left. Under miscellaneous , click on FAQs. They have a good explanation and pictures on how to determine what your rim size and offset, and bolt pattern will be.
1 - 7 of 7 Posts
