1 - 6 of 6 Posts
Hi guys, when I was cutting the grass yesterday with my 129 and the pulley and bracket that puts tension on the deck belt came flying out. So I picked up the pieces and took it back to the shop. It looks like I am missing a pin that would go thru the deck bracket and into the pulley bracket and then into the other side. With a cotter pin on the outside.
Does anyone know of a part number for this?
I looked in my manual I cannot find it.
Here is pic, it is the dark ring area that looks like something should go thru it.
Discussion Starter · #4 ·
Thanks 48 willys that is exactly what I was looking for. I did manage to fabricate one out of 1/2 inch threaded rod. It is holding for now. It seems pretty tight. I did not realize that was 1 long pin. I thought it was two pins.
anyway thanks a lot, you made this repair a lot easier.
Threaded rod is ok for a temporary fix, but you should replace it with a solid rod as soon as you can. The threads will wear off quick, and wear out the pulley brackets, throwing off the pulley angle which will make the belt fall off.
1 - 6 of 6 Posts
