1 - 6 of 6 Posts
Got off the trailer. and started checking things out no spark, brakes were locked up a couple of turns and rolls fine. Won't turn over with the key jump the solenoid and got 90. Psi lots of over spray (paint) and as someone said this tiller will not fit my 1450 and is for a mf 1200 or snapper 1600 ? will it fit anything else
Discussion Starter · #2 ·
Drive line was gone, it looks like the splines are worn down a bit on the transmission end. can this be fixed? Got new points and condenser coil is good. New starter switch. But still can't start with the key. Po took off the seat switch. And taped the wires together. We're can I get the wiring diagram for this tractor.I can get it to run jumping the solenoid and starter fluid. Gas tank is missing the fuel valve at the bottom of the tank and one more thing is 100$ bucks for the deck as is to much I still have my MF 16 that I think some parts work on this 1450 but not sure and I really hate to do that
In the manuals section of forum is a listing for the service manual for the MF 14&16 tractors. Might be worth downloading to check out. also saw an owners manual that said 1450. The manuals tab is at the top of this page, third tab from the right Don
Also a close up picture of the serial# ID tag on the tiller may help get a better response. The3650 PTO Rotary tiller Manual is in the manuals section. Don
Discussion Starter · #5 ·
New points and condenser cleaned all contacts and fuel pump and runs good.left wheel looks a little close to (tie rod) ??? Needs adjusting.next the drive shaft. is this a weak point I've heard of 3 other tractors that the spline have stripped
Discussion Starter · #6 ·
fuel pump was bad. (dirty) cleaned everything still nothing, last I checked pto switch rusty. Clean up to and took off!!! Runs good .I think it needs more help revs up to high( I think) and at low throttle shakes but is smooth sounding drive shaft next is this a weak point (splines)
1 - 6 of 6 Posts
