1 - 10 of 10 Posts
I have an old 1477 Bolens with a front loader - the S14D wisconsin has been rebuilt but still seems to have problems running - I'm not sure if the compression release in not working properly and that's why it's tough to start or if the coil spark is too weak
before I spend money on a coil, is it critical to get a "wisconsin" coil or could I use a regular coil
thanks
Art
As long as it is the same kind of coil it doesn't matter. I meant internal resistor or non resitor! They usually say but I don't remember which one the wisconsin uses.
Welcome to GTT. Do not just guess and replace parts. Download the manuals you need from out Manuals Section and then work your way through a troubleshooting section. This will take you step by step through the diagnosis proceedure so that you can find what is really wrong. I'd check the points first. The points plungers leak on those engines and can cause intermittent problems. When you need parts, our sponsors are very knowledgeable and helpfull. Good Luck, Rick
I dont know what the difference is but there are different ones for the solid state ignitions and regular battery ignitions, the Wisconsin distributor tells me theres a difference so I carry both types.
. Points have to have a resistor if 12v.,inline or in coil, no points no resistor
Discussion Starter · #8 ·
thanks for all the responses -
to clarify -
solid state ignition so no points
12 volt system
so the only coil consideration is internal resistor or no internal resistor? next question is what does the solid state system require?
did some resistance testing on the old coil and a new one at NAPA, both seem to have the same readings - stuff I'm reading seems to say there should be resistance between the secondary circuit and the case, I'm getting nothing so maybe it's the wrong coil to start???
thanks
Old, but not dead -- yet!
to clarify -
12 volt system
thanks
There should be an ohm reading across the two small terminals.
There should be an ohm reading across the + terminal and the secondary terminal.
There should be no continuity (infinity reading on meter) between the secondary terminal and the case.
1 - 10 of 10 Posts
