1 - 9 of 9 Posts
I finally got the deck on my 1556... What a JOB.. The tractor and deck were from different family's and so that my have been most of the problem.. Trying to get the 4 pivot points to line up took hours..
I have lots of ????? about puting deck on,,, but i will go slow and hope I say it right...
First,,,, I did get it on... :dancingbanana: with a pry bar and hammer... and it runs really well, but it's got to be easier than that..
There are 2 ear shaped lobes on the support going from side to side.. the support that goes up and over the gear box... 1 lobe on each side... ARE those held on with allen screws,to adjust in and out..???--- If so,,, that would have helped... I couldn't find an allen to fit it.. No size seemed to be right.. Maybe stripped...?
Is it easier to mount the arms on the tractor first,, then the deck to the arms.. or all in one assembly on deck, and up to the tractor..??
When raiseing the deck,, hydrollicly , it only wants to raise one side.. I Do need to adjust the deck yet. ( one side is 3" one side is 21/4 ) But the right side where the lift arm is,, is the only side that lifts.. I have the manual for adjusting and that is next..( No rain please )
I would like to take the deck back off to get a better look at these things ,,But it's such a job..
And I need to adjust the lift lever...to lower ,,,seems to be out of adjustment.. It's hard to even see it without taking the side cover off,, which I don't want to do if possible..
I have more ???? to come as ,this is my first tube frame Thanks sodi
This is the best pic I can come up with..
Is there a better manual than the one in our manuals section,, that came from Sonnys..?? I can see it OK on the computer... But I printed it out for the garage to go step by step,,and pages 3--4--5 the pics are almost washed out..
I wanted to put a deck with that setup on my 1256. I could not see how the lift brackets would work with the hydro so I ended up switching the mounting from the old deck to the new one. Had to drill 2 holes but it works like a charm. It is my weekly mower.
Oh boy...... I call that one the 20 minute plus deck :D
I dont know why Bolens made the later series decks so complicated but these can be a bit of a chore to put on.
I dont have any decks like this here so I cant help with installation pics, I may be able to pull a owners manual from the stack that may be of some help to you.....
That mower deck really is a 1 minute deck if you have the right parts to hook it up.
You need four pins like these.
This is how it's hung on the pins
And this is the correct lift bracket for a hydro tractor
Discussion Starter · #8 ·
Thanks DR. B I could use better instructions...
John WR Thats exactly what I have... It's on the tractor now but what a job...I'm thinking I should have taken one side of the support bracket off,,and assemble it in pieces on the tractor,after blocking it up to the right level..The springs on front seemed to have so much tension to alien the pins..
John,,,,,,,, If you ever have time,,,, maybe you could give a blow BY blow as how to do it EASILY !!
Thanks sodi
1 - 9 of 9 Posts
