1 - 9 of 9 Posts
Has anyone rebuilt, know how to rebuild or know somewhere that rebuilds welded hydraulic cylinders? Thinking about cutting this one apart and trying to fix the leaking seals. This one is an extra I can experiment with before I take on the 3 point lift cylinder that is also leaking.
thanks!
Discussion Starter · #3 ·
Thanks, I will look into that. I had a guy that services heavy equipment look at it and he said it was a throw away. Gald I came to the experts!
Yes i also thought they were welded closed but they are not take the bottom pin out and it will push back through the bottom then take to any hydraulic shop and spend $15 bucks and ask them to change out your seals Watch them as they do it and buy an extra set of seals so you can do it yourself next time Kinda scary how simple it is
Unscrew the ports, remove the shackle from the rod. Push rod, piston, gland and all out the back end. Measure seals and backers and order from some place on line.
1 - 9 of 9 Posts
