1 - 13 of 13 Posts
i'm making the lower lift arms for my 3pth. i got all the measurements but don't have angle to bend it. i have looked at alot of pics and 45degres looks about right. if one of you guys can get out that trusty protractor it would help me out. i figure the bend in the top arms is the same as the lower arms. i also just finished up making a muffler. it's all tacked up, but i'm afraid to weld it ( i'm a 50/50 welder) 50% not bad and 50% garbage.
I'll try to get a look at one of mine today. On your welding....go over every weld twice & you should get that number up to 75%!:D
Get some of the same metal you made your muffler from and practice, adjusting the heat and the speed you move. After a little practice you'll be able to weld an ice cube to a screen door. It's like anything else, practice, practice, practice and, don't give up. Good luck.
I am sure your muffler will turn out alright,I build mufflers all the time,and they work great.
tinnern said:
...After a little practice you'll be able to weld an ice cube to a screen door...
:bigrofl: I hope to one day be THAT good!
I'd like to be able to weld an ice cube to another ice cube,that could come in handy.LOL:rofl2:
Premium Member
Hey tyler just saw this and tommoro i'll take my protractor outside and get the angles for you providing someone else doesn't posts them first . Larry.
Discussion Starter · #10 ·
yesterday went to dad to practice my welding. started off with the arc, not good kept blowing thru. then the mig, good for a inch then blow thru. more practice. since we had the welders out i made up all the seat brackets. thicker melt good welds. i guess the guy that owned it before me, put a aftermarket seat on and throw away the other parts that would not fit. one more ? on my 1650, after sitting all night, i'll start it and get white smoke not alot but it clears up right away. would it be weak rings or bad valve guide since it has ACR
Premium Member
Here's pic's and the angles are 45 degrees, also added measurements to show what it looks like.Larry
Thanks for covering for me Larry. Been crazy here the last 2 days. Family Christmas dinners, vacuum pump motor failure in milk parlor, & parlor water heater on the fritz.
1 - 13 of 13 Posts
