1 - 6 of 6 Posts
It's bin over a year but I've finally got the loader hooked up,JD wheel weights,ags on. Wheel Automotive tire Motor vehicle Tread Gas
Tire Wheel Vehicle Automotive tire Locking hubs Now I need front tires the 20 year old two ply turf tires aint gunna cut it for long,any suggestions? I think I remember a thread on replacing the hubs with one off a car?
LOaded it up with 450lbs had no probs lifting but the tires were almost flat,need some weight in the weight box.
I have 4.00 x 12 on the PK with tri rib tires , the problem with them and I would think any tires with sharp sides ( like whats on yours now ) the grass seem to peel up with a loaded bucket while turning , maybe a multi rib 4 ply would work better . Broke a hub last year on it so I know your concern . Maybe you could try to reinforce the ones you had . Al
chopperfreak2k1 said:
i agree. these are probably the best tires for turning grip that will not destroy your lawn. grip better than turfs, don't bite as hard as a tri-rib. good call Daniel!!
They sure like these tires a lot! For $125 + the $26 shipping I would see about filling my old tires with foam.
I use 18x9.50-8 trailer tires with 4 plies, stock hubs and spindles and no tearing up the turf. The bucket weighs 210 lb and anything less than 500 lb in it constitutes a light payload.
The only front end failures have been failed weld on the axle tube where the spindles are attached and one rim where the spyder failed. Hubs, bearings and spindles are all fine, and original, with 2500 hours on them.
1 - 6 of 6 Posts
