1 - 6 of 6 Posts
Deceased
What lift arm(s) does the 18010 3-pt for the early large frames use?
Would the ones for the 18093 tiller work?
Deceased
i think they would be to long... if you need to make some they are pretty simple to make
Deceased
Discussion Starter · #3 ·
Well, the question is moot now.
The 3-pt that I was looking aat, had the lift arms with it. :D
Deceased
Discussion Starter · #4 ·
Thought I'd add to this thread rather than start a new one.
I got to thinking that if the 3-pt is installed that it may interfere with mounting my tiller.
Is that the case, or will the tiller mount with no issues even if the 3-pt is there as well?
Second, I've found a 3-pt sleeve hitch adapter on eBay:
Category 0 3 point drawbar with sleeve hitch adapter | eBay
Have any of you folks used something like this, and if so how well did it work?
Third, I've seen some adapters for 3-pts that make changing/mounting implements a breeze. Problem is, all that I've seen are for CAT 1 and above. Does anyone know if something like this is available for CAT 0?
Pat's Easy Change System Product 1
Deceased
its one or the other, tiller or 3pt cant have both on at the same time
Deceased
Discussion Starter · #6 ·
HHHMMMMM...guess I'll have to come up with a BHT (Big Heavy Thing) to put on the 3-pt.
I know some guys with larger tractors have used 55 Gal. drums filled with concrete, and a rod thru the center, but I think the diameter would be too much for a Large Frame.
I wonder if something like a beer keg would work? I'll have to do some research. :D
1 - 6 of 6 Posts
