1 - 8 of 8 Posts
I would like to get some cad plans together for the 18010 3 point hitch for the earlier large frames. I need length, width, thickness of materials etc. Also what size are the ball joints? Are they 5/8 inch bore on each end of the arms? I am not sure which hole on the tractor they attach to on the back of the transmission. I think one of the holes is a 3/4 inch hole and the other is 5/8? Also the extended and collapsed length of the top link would be great.
Here is a link to the 18086 plans in pdf. I would need similar measurements. This is hosted on another forum so it might not be downloadable to everyone.
http://www.mytractorforum.com/attachment.php?attachmentid=135617&d=1293111578
If I can get everything I will see about getting it put into cad and then save the plans as a pdf to share with everyone.
Also is there a way to lock the 18010 3 point hitch up? If one was to use a 3 point hitch to attach a weight bucket and still want to use the plow on the front, they both attach to the rock shaft and if you move the plow up and down the 3 point hitch would also move up and down correct?
Deceased
... Also is there a way to lock the 18018 3 point hitch up? If one was to use a 3 point hitch to attach a weight bucket and still want to use the plow on the front, they both attach to the rock shaft and if you move the plow up and down the 3 point hitch would also move up and down correct?
I'm assuming you mean the 18010 hitch. I guess it would be possible. You would probably have to lock each lift arm independently.
Yes for the 18010. I corrected the above mistake. The 18086 seems to have something like that to lock the hitch but I didn't see one for the 18010.
Could one make the 18086 fit for an earlier large frame? Or create hybrid like the 18086 to fit an earlier large frame that has the top link arms? This would be a one off build.
Link worked for me and now printed out. I see plenty of dimensions and these are very easy to read plans. On the locking part....I bought a tractor once and they had the top link connected straight to the drawbar between bottom lift arms. It wasn't gonna move! You could leave off the lift link if you need to use it for other attachments. The top link may be in way of setting a box on the arms, but you could do two bxes or slot to work around it. Really, you don't even need a 3pt to make wieght box, just run angles to the frame and upper support off this link mount and build box to fit! Ct 0 hitches have 5/8" balls, Cat 1 uses 7/8" or maybe 1". You can put bigger ones on the outer end and use bushing sleeves to make smaller for cat O stuff. BUT, be careful using Cat 1 implements, might be too heavy for your rig and lift to handle.
I have the pdf for the 18086 hitch. What I want to do is make a cad drawing for the 18010 hitch just like the one I linked above for the 18086 hitch. Can anyone take measurements for a 18010 hitch so I can try and make the cad drawings? We can then have cad drawings for both hitches.
1 - 8 of 8 Posts
