1 - 10 of 10 Posts
Nut Case
Cat. 0...keep an eye out for Brinly made stuff.
Welcome to GTT,watch your local craigslist for attachments. When you have a minute post some picks of your tractor.
There are also adapters that will let you use sleeve hitch attachments. There are usually several on eBay, but lately they've seemed pricey.
I adapted a cat-1 rear blade to mine by welding on cat-0 pins, the lower bars will open enough to get it on. That won't work with everything.
Sometimes you can face the pins inward to get a cat 1 implement onto a cat 0 hitch.
BTW, as you're looking for implements be advised that many Sears tractors used a proprietary cat 0 hitch. Implements for that hitch may not work on your tractor. That hitch is 12" wide instead of the standard 20 and the top link geometry is different. At least 90% of the cat 0 implements I see on Craigslist in my area are the Sears proprietary ones.
This Sears plow has the proprietary cat 0:
1967-sears-suburban-tractor-10-single-pl
  • Like
Reactions: DMAX
Welcome to GTTalk Wacastillo. Being new you may not yet be able to download from our Manuals section so I will post it here for you. These are some dimensions for Cat 0 Hitches Thanks to member IamSherwood.
View attachment 17788-Cat0 3pt.pdf
Pics will be your Payment.
  • Like
Reactions: limebuzz
17788-Cat0 3pt.pdf
The diagram on the first page of that is not to spec. It shows the hitch between arms as 16"(1'4") where the category 0 specification is 20".
While most lift arms will swing enough to accommodate that he should expect cat 0 implements to be 20" wide.
Thanks MiCarl
I should have posted that as well.
Discussion Starter · #10 ·
Thanks for all the responses I went and picked up my snapper about a week ago and ended up getting a multi hitch a plow and a disk and mower deck included in the deal all were with the stuff from the factory I was told. I am getting ready to get a quick hitch for category one and make it fit a category zero so I will have an adapter.
1 - 10 of 10 Posts
