1 - 9 of 9 Posts
Premium Member
If I had a three point implement I would use it but I don't have any yet. I would like to get a tiller for my 1655.
I have a 1650 and don't have any PTO equipment for it yet but I do have a 3 point rear blade, 12 inch one bottom plow and a pallet lift for the 3 point.
The only actual 3 pt. implement I have is a cat 0 cultivator I picked up last spring (second hand, not sure of the make offhand). I have a cat 0 sleeve hitch adapter that I use with my sleeve hitch single furrow plow (may have been off a Case GT). I use both with good results on my garden. I've also rigged up a snow plow blade to use with the sleeve hitch adapter on the 3 pt. No PTO implements - if I could find any it might justify buying the missing parts for my PTO...
Premium Member
I have a massey 4850 tiller,I have a homemade single furrow plough,a homemade cultivator and a homemade tandem disc. I have a set of forks that I use to move things on pallets around.I used to have a stump grinder that I used on the 3 pth but have converted it to front mount.Larry.
I made new lower lift arms for my 1855 so that i could use all of my sears 3pth equipment on it. I use mold board plow, disk, grader blade, cultivators. I use a sears toolbar as a draw bar so I can wrap a chain around it and drag stuff and I also use a set of log tongs on the draw bar to lift and skid logs. I dont have the PTO on it but I do have most of the parts, I hope one day to be able to reinstall it and convert some of my gravely waik behind equipment to fit. I am also looking for a portable welder that has a blown engine so that i can convert it to run off the PTO someday.
Premium Member
I have a 4' back blade, MF 4250 tiller (widened to 53") , 2 bottom plow. I also have a Simplicity cultivator & a tine harrow, but they are sleeve hitch & I have to use a 3pt adapter to use on my 3pt lift tractors.
1 - 9 of 9 Posts
