1 - 12 of 12 Posts
We did some work that required me to remove the rectifier out of the way. After getting everything back together I drove it to the shed. I noticed that one black wire that comes from the rectifier was grounding on the firewall. In looking at the wiring diagram I think it goes onto the passenger side of the ammeter. When I touch the wire to that side it gives a dead short . I'm thinking that I blew up the rectifier or that wire goes somewhere else. Would anyone have a picture of that area or any ideas? Thank you for any thoughts on this.
  • Like
Reactions: blackjackjakexxix
Tinker Master
The rectifier has two HOT or 12V positive wires connected to the studs. The ground is provided via the case/mount. One hot wire comes from the stator/flywheel area (~28 V AC) and the other is one side of the AC circuit which is 12V + DC.. That wire should go to the battery or key switch somewhere but I don't know the specifics for your machine.. hope this helps..
Discussion Starter · #4 ·
Where is the other end of that wire attached? If it goes to the rectifier - (minus) the loose end should ground under the start solenoid mounting screw,
Yes to goes to the rectifier/regulator. So what you say would make sense going to ground. I'm going to have a closer look at this. Of all the pictures of the tractor I have I can't believe that I never took a picture of this area prior to removing that regulator. Thank you for the idea.
  • Like
Discussion Starter · #5 ·
If the rectifier/regulator is bad I saw one on ebay for $150 it's NOS. I may get that one. If anyone here is selling one I'd rather buy from here. It is a syncro 277064.
  • Like
I have used, and still use the $14.xx chinese copys off Ebay with good success.
150 bucks is a lot jing for a .75 cents worth of Aluminum, and .50 cents worth of internal bits.
http://www.ebay.com/itm/130605746942
May have to modify the way it mounts, and obviously add spade connectors, but it does the exact same thing.
Discussion Starter · #7 ·
Wow that's amazing. So this will work in place of mine which is a rectifier/regulator? Do you know how to match up the wiring from the old one to this new one on the 1886
  • Like
Tinker Master
Terminal ID: Stator-Battery-Stator
You need 2 wires from the stator and one to the Battery or battery side terminal on the solenoid..
Tinker Master
***The Rectifier case must be connected to a good ground!**
Discussion Starter · #11 ·
Awesome thank you guys I'll get one and try it out. Mine is 30 amp not sure what the one on eBay is I will call them.
Discussion Starter · #12 ·
Well after removing the rectifier I found that I pinched the wire that goes to the ammeter. This resulted in the direct short to ground. I replaced the wire. It now runs and charges as it should. Thank you to everyone for you help and ideas. We can close this one????????
1 - 12 of 12 Posts
