1 - 6 of 6 Posts
Discussion Starter · #1 · (Edited)
since every part I seem to touch on my M-1 either needs painting, cleaning or repair,
I decided to start documenting all this.
it might be nice for others to have dimensions and common descriptions for parts that we only see in manuals and parts lists as a number (like S3A42/8221042 is a 3/16x1 inch square shaft key)
basing this off the parts list from the 1952 manual
I have enough technical training that I should be able to whip up some cad files for parts, so someone could (possibly) build a from-scratch replica
I haven't found anyone doing this already, and thought it would be good to set up a parts list that is a bit more descriptive
requests for specific parts appreciated
Discussion Starter · #2 · (Edited)
D-A28 axle collar
1.015 id (1 inch oversize)
1.63 od (1-5/8)
.5 thick
one setscrew 5/16 by 3/8 long, 18 tpi with a 5/16 square head that is .25 tall (need to verify size and threads)
Discussion Starter · #3 ·
da-104 pulley shaft set collar 8021104
.753 id (to fit 3/4 shaft)
1.25 OD
3/8 thick
one setscrew 5/16 by 1/4 long, 18 tpi with a XXXX socket that is flush for clearance (need to verify size and threads)
Discussion Starter · #4 ·
simplicity DA-31 axle grommet (nitrile/Buna-N Rubber , oil proof)
simplicity 8021031
AN931-16-22
MS35489-23
MIL-G-3036 (rubber type)
mcmaster 9307K61
not grainger 3MRP2
MFR Model# MR-200-0524
Discussion Starter · #5 ·
DB-8 gear case gasket 8022008
1/16th gasket paper?
working on file for lasercut. image for placeholder 200 dpi for scaling
401483
Discussion Starter · #6 ·
I need to order these as the pulley bushings on my machine aren't there anymore, and might as well try to get replacements for the axle too
S2A43 axle bushing 8191043
for 1-3/16 (maybe 1-1/8?) OD for 1 inch shafts by 2 long high load sleeve bearing
S2A44B pulley shaft bearing 8191044
pretty sure it is a 1 OD for 3/4 shaft by 1-5/8 long (looks like porous bronze, your choice to go to high load)
1 - 6 of 6 Posts
