1 - 20 of 201 Posts
Collector of Rusty Junk
I thought I would start a new thread on the restoration.
I like to do videos of my updates, I can explain things better. I will do a video in the next couple of days on the work so far.
But I have removed the hood, the wiring harness, the gastank, the battery, and the deck so far.
Deck looks good, it even has new blades, had some problems removing it. The pins were different sizes, and the 16 penny nail had to been straightened first to remove it. the deck does spin, I will work it later.
Discussion Starter · #2 ·
Found the correct wiring diagram for the MF10 with S/G.
Update
markdombroski said:
Cool video log. Looks like a fun project!
:ditto:
Thanks for the update video. I always find it kind of interesting to look at all the issues that have been dealt with in the past by PO's, like the nails in your linkages. I guess many people consider these old GTs as worthless and won't spend even a dollar on fixing them.
Yeah, there have been items in the past that Dad and I saved, that we left some of those modifications in place. "Character" is how we refer to them:D
One of my favorite reuse items is an old clevis that Dad has. You can still see the "teeth" in it as it used to be a file and has been heated and hammered into a U. Making Do Without was how you sometimes had to do it.
Discussion Starter · #8 ·
OK here is the coil setup. It has the older point style coil with a small box.
And it also has this number tag on it.
Electric Tractors
I think what you have there is a replacement engine judging by the coil on it, that style was not used in production engines but was used on rep. engines. Back then you could get rep. engines or short blocks.
The rep. engine would of come with the coil that you have and under the flywheel you should find a magneto coil as well.
The small box is aftermarket points eliminator, why it's there???
The SBH tag is a short block replacement tag, it is quite possible that the original engine was replaced with a replacement engine then when that failed a short block was put in which would of had the coil, magneto, flywheel carb, swapped over.
SBH-237B indicates that it is a 12hp HH engine.
If you look at the flywheel side of the block, lower left hand corner, you will see a #
10 for HH100, 10hp
12 for HH120, 12hp
What does yours say?
Discussion Starter · #10 ·
Well Well Well looks like I have a 12HP engine.
Discussion Starter · #11 ·
OK now will a 10 HP carb be the same or do I need a 12 HP carb?
Electric Tractors
10, 12 carbs interchangeable, maybe the 12 carb has more airflow???
Either one will work.
Discussion Starter · #13 ·
Thanks!!!
I think I have a line on a used carb local.
Discussion Starter · #14 ·
Also the head has a few fins missing, I was going to replace the head, will a 10 HP fit?
Electric Tractors
I believe the 10 and 12 heads are the same but the HEAD GASKET is different.
Discussion Starter · #17 ·
Probably the bigger bore.
Discussion Starter · #19 ·
I may have to rebadge it as a MF10+2 LOL
1 - 20 of 201 Posts
