Assuming the 15amp regulator fits in the same hole on the cooling shroud, I assume you could just bolt on the 15amp stator in place of the 10amp, bolt on the 15amp regulator and go. Probably the same flywheel.
Assuming the 15amp regulator fits in the same hole on the cooling shroud, I assume you could just bolt on the 15amp stator in place of the 10amp, bolt on the 15amp regulator and go. Probably the same flywheel.Do you know if there are any good threads or videos out there on how to do the swap? I.e. is it just the stator and regulator that get replaced or are there other things that would need replaced/adjusted to compensate for the change?
I really appreciate everyone’s help here! This is the first project of this kind that I’ve done so it’s good to hear from folks with more experience.
Everything online seems to point to them having the same flywheel. I’m thinking the swap may be my only option if I want to replace the stator. I’ll keep everyone updated if/when I go this route!Assuming the 15amp regulator fits in the same hole on the cooling shroud, I assume you could just bolt on the 15amp stator in place of the 10amp, bolt on the 15amp regulator and go. Probably the same flywheel.
I’m planning on using John Deere branded AG & Turf Green paint. I know that may be a little lighter in color than what was originally on the tractor. I haven’t yet painted any of the green pieces.What type of paint are you using on the larger green and other pieces?
Yep, they still carry both the Classic and Ag&Turf Greens. There’s a lot of argument on various forums over when and how often Deere changed the colors on their equipment. Some people say there was only one changeover in 1989, others say that the shades have changed multiple times over the years and there’s no public record of when those changes happened. I ultimately decided to go with the Ag&Turf green because it is a little brighter and I like shiny things. And very few people will be able to tell the difference unless it’s sitting next to another Deere painted in Classic Green.Don't know if they still do, but Deere dealers were carrying both Classic Green and AG & Turf Green (and Sabre Green)
Classic Green
TY25644 340 g (12 OZ) Aerosol
TY25655 946 mL (1 QT)
TY25670 3.78 L (1 GAL)
Sabre Green
TY25613 340 g (12 OZ) Aerosol
Silver Jubilee
TY25675 340 g (12 OZ) Aerosol
Ag & Turf Green
TY26019 12 mL (0.4 FL OZ) Pen
TY25624 340 g (12 OZ) Aerosol
TY25643 946 mL (1 QT)
TY25656 3.78 L (1 GAL)
TY25620 3.78 L (1 GAL) Fast dry
TY25629 18.9 L (5 GAL) Pail
