1 - 18 of 18 Posts
I am about to start a new educational series in MF's. I am acquiring 2 MF-10's
One is supposed to be a hydrauiic
Both have decks and I don't know the condition of the decks. Pictures will follow once I get them home.
My collection is growing quickly and I am running out of storage space but I will find a solution to that.
Hmm not sure what you mean by hydraulic but if you mean hydrostatic I don't think they made any hydrostatic mf 10s. However a 12 would be very similar and was made in a hydrostatic model.
Discussion Starter · #5 ·
I was told and i havent seen it yet but I was told one had hydraulic lift so thats what I am hoping for. Time will tell
This is exciting news......
Looking forward to seeing what you've found.
If you're getting an electric, over hydraulic lift on one of them, that's a big
bonus. They're hard to find.
Pics, pics when you can. :rocker2:
Discussion Starter · #8 ·
Well(and yes that is a deep subject) I got to see them last night, they will be coming home this weekend.
It is sad to see an older person suffering from dimentia but I learned some things about them. Neither one has a hydraulic lift, and what he calls a 3 point lift is actually a sleeve hitch.
They both have mower decks though I am not sure if they are complete. Time will tell as I go through all of the loose parts laying around.
One has a starter generator and headlights ( he states it also has points and condensor for ignition), the second one does not have headlights and has a conventional starter and the solid state ignition ( the flywheel shroud is laying beside it) and it is missing the belt from the engine to the vari drive.
The second one needs a seat and some seat hardware.
From what I could see while standing there looking at them and looking around I may be a frequent buyer ay Joes outdoor for some missing parts. I have started downloading manuals to get a better idea how to finish putting these back together.
I will take the 1655 and a tow strap and pull them home this weekend ( they are less than a 1/2 mile from home) and then go back for all the loose parts I can identify.
I am hopeful I can get them up and running so they can be useful to mt daughter & son in law, and possibly my nephew.
And then again maybe they will want a new shiny toy and if thats the case my stable will grow by 2.
Later guys and thanks for being patient
Good luck with the puzzles!
Well an OEM sleeve hitch is still a really nice find, and it's probable that the belt start is points ignition.
I get really jittery when there is a non runner, CDI, and the tins are off... Hopefully it's OK. Make sure they didnt change the ignition switch with the wrong one. Happened a lot, unfortunately.
I have a bunch of 10/12 parts around here, so before you go wild... let me know what you're after and we'll see what can be worked out.
They came home last night. They appear complete, that does include mower decks.
In the 2 photos attached the tractor without a hood and grille has the starter generator and also appears to have an aluminum dash. And if my suspiscion is correct on the dash that will be the tractor I will hang on to for my daily use. I do have the hood and grille sitting off to the side and not shown in the photo
The second tractor appears to have the SSI ignition system.
I will be making an inventory of small items to locate to include mower blades, belts and then I will start on trying to get the engines running. These wont be rushed and as time permits I will do my best to keep the group updated. But the daughters wedding comes first in July
Discussion Starter · #14 ·
The wedding is still 6 days away, but yesterday the tractor with the starter generator not only ran, but had the mower installed and mowed the neighbors yard. I can say this witthout reservation the MF10 with its 42" mower deck does a better job of cutting grass than the 1855 with a 54" deck.
This one requirred new blades, 2 belts, a starter relay, carb cleaning, some wiring repair,and a bunch of hardware.
Oddly enough this deck uses a rubber washer between the blade and the cup washer that the blade bolt goes through. These are no longer available through AGCO. But they can be made.
I took a piece of flat rubber stock I had that was 3/8" inch thick and a 2 inch hole saw and cut three washers. Then I used a 1 inch hole saw and cut the center hole. Because it was rubber the holes were not the exact diameter needed, and that was resolved with a drum sanding wheel in the Dremel. All three fit snug over the spindle shaft and appear they are going to work nicely.
After the wedding #2 will get some TLC.
The second mower reck will need a new front roller and the bushings in the rear roller are beyond shot, their existance on the shaft is only a reminder that they once existed. Hopefully I can find them somewhere other than AGCO.
Great news, that you got the one going.
They sure are a joy to run.
The bushings for the rear roller, are readily available from a place like Fastenall.
From what I recall, it's just a stock bronze bushing.
For the front roller, take a look at boat trailer rollers. They are inexpensive, tough, and
easy to alter to fit.
A couple of nice tractors. Doesn't look like very much rust to deal with just some parts. Good rescue projects.
1 - 18 of 18 Posts
