1 - 18 of 18 Posts
Take a look at the following pictures and let me know what you need or buy the tractor(s) as a lot. None of them have good usable tires.
I also have a set of Ag Tires on rims that I will sell and they are for a 1655/1855 $125.00 for the set
I have a 1600 with a peerless 4 speed transmission and a usable hood.
the 1650 only has the differential, the transmission was removed and used for parts
I have one good usable mule drive for the 1600, and a hyd spool valve
If all you are looking for is parts the following is a listing of what is readily available
I have a Dash
2 hoods
2 front axles
I also have 1650 Differential I do not have the hydro
Mule drive is 50.00
Spool Valve 75.00
I have a complete 3 pt hitch less top link
I still have the Ag tires and Snow Cab
The 1650 is $125.00
the 1600 is $150.00 The PTO assy is sold
All items are before shipping and if you meet me in Columbia Mo zip code 65202 where these are located I will help you load them on a trailer. I do not wish to place these on Ebay nor do I wish to find them on Ebay in week after I sell them . I prefer they go to someone who will use the inventory of parts for their collections .
Good luck and thank you
I
Man I wish I were closer. I'd take the 1655 off your hands if I did!
How much for the 1655 Drive shaft and the Rear PTO cover? I would take one or two off your hands if you were closer, guess I will have to settle for stuff that can be UPSed.
Daniel, Second row last pic on the right. Look at the hi/lo shifter and you can see a silver plug coming out the right side. That is the shifter lock out that keeps you from shifting unless the brake is pushed in. It has a spring loaded plunger that blocks the shifter. It has a cable connected to the brake pedal. You push the brake and the plunger is pulled back into the housing which will allow you to shift. Its been a year or so ago we were talking about that think with somebody else and you mentioned that you had not seen one.
Well now I HAVE seen one! Thanks for pointing that out!
How much for everything and how soon do they need picked up?
Wow...I'd love to have everything as well. Too much going on to drive that far right now though...
Discussion Starter · #14 ·
I can store it for anyone who decides these treasures are to good to pass up. To that end I would like it picked up before the first snow fall.
Texas Deer, are you going to be making a haul up there?
I would love to buy those mounted Ags.
Can someone tell me more about the hydro spool valves on these?? I would like to get that as well if it is something I could use to build a add on lift for one of my other GT's.
I know it is a longshot since this thread is nearly a year old ........ but are any of the plastic dashes still available?
1 - 18 of 18 Posts
