1 - 8 of 8 Posts
Ok guys, I have a Snapper 1650 and want to know if the 3 point hitch from a Snapper 1855 is interchangeable without modification?
Thanks guys,
Reg
Looks like it will fit. I think 1655 and 1855 are the same but perhaps it's best to wait for someone who has first hand experience with them.
Discussion Starter · #6 ·
An auction is coming this Saturday for a parts tractor (Snapper 1855). I've emailed the auctioneer to find out if it has a 3 point as the picture is poor. I don't think I see a second hydraulics lever but the black plastic is busted there so I don't know for sure. This is probably all for naught but trying to stay on top of it just in case.
All tractor with the Eaton hydro have different hosing and plumbing than the Sundstrand units.
MF Tractors with the Sundstand hydro have the same hoses and plumbing be it the 50 or 55 series. The Sundstrand hydro is only found in the MF tractors as a rule. I have nothing wrote in stone on that but have personally never seen an MF with an Eaton. A few people have tried to pass a Snapper as an MF around here with a paint job but always lose the Serial tag in the proccess.
There may have been a few Snappers come out of the factory with a Sundstrand unit after Massey discontinued there contract with Snapper because of left over stock. I have not seen one myself.
Snapper tractors (50-55series) have Eaton hydros and are easy to ID. The Eaton unit will be rounded and have cooling fins and an external filter mounted under the left hand rear fender. The Sundstrand uints have the filter mounted directly to the bottom of the hydro.
All use the same Peerless 2600 axle.
Hope this Helps.
Discussion Starter · #8 ·
Hope this Helps.
From my restoration I know mine is an Eaton. It's a Snapper I painted MF (As a tribute to my Dad's old MF). The Parts tractor is a Snapper also, but can't see actual tractor only one picture right now so can't confirm hydro. Excellent info, thanks a bunch.
1 - 8 of 8 Posts
