1 - 4 of 4 Posts
does anyone have diagram of 3 point hitch for ht 20 large frame tractor? i am going to make one cause new
is costly.have seen some drawing but you can't read the measurements at all.thanks in advance
I agree, the kits are terribly expensive. If I was going to go to the trouble to create one, I would probably set it up with it's own hydraulic cylinder. The one thing I don't like it the fact that you cannot run a front attachment and rear attachment at the same time due to the rock shaft configuration. If the rear 3pt had it's own independent cylinder you could have a front blade and a rear blade etc.
I did locate a PDF online - however I did not create the CAD drawings and cannot vouch for their accuracy. However, they may help you with the necessary fabrication.
Nick
I thought I saw someone put an electric one some where. I'll look for it ...
Nick
Discussion Starter · #4 ·
Nick
thanks a bunch thats all i need to make one.drawing is very good and readable
1 - 4 of 4 Posts
