1 - 11 of 11 Posts
· Mark J.
I have been looking over my new to me Sears/Brinly 3 point plow for several week while waiting for some parts to arrive. Here is what it looked like when I got it.
Wood Motor vehicle Automotive tire Fender Gas
Wood Automotive tire Electrical wiring Gas Automotive wheel system
Automotive tire Tire Wood Wheel Gas
The first thing I did was order new Cat 0 pins. The PO had drilled out the holes in the plow for Cat 1 pins so I order a Cat 1 to Cat 0 pins from Ebay. They arrived the other day so now I could spend some time fixing what was wrong with the plow. This plow was used be a big tractor then a GT so it has sustained from damage. Here are the old and new pins.
Wood Bumper Gas Auto part Composite material
Wood Gas Cylinder Metal Auto part
Nickel Gas Wood Nut Fastener
Wood Tool Gas Machine Nickel
The lower pin hole for the mast assembly was bent so I used my 20 ton press and bent it back into shape.
Door Wood Hand tool Automotive exterior Hardwood
Wood Door Gas Font Tints and shades
I also notice the PO has cut the one side of the top link mast off and then welded it back on. Not sure why? Maybe it was bent as well and the only way they could fix it was cut it off and weld it back somewhat strait.
Wood Brick Gas Hardwood Building material
Next up was to remove the coulter blade to straiten the rod holding the coulter. I also greased the coulter and added some washer and a new carter pin to hold coulter to the fork. I also grease the gauge wheel as well. They both were dry as a bone.
Automotive tire Wood Motor vehicle Bicycle part Bumper
Bicycle tire Wood Bicycle part Bicycle fork Bicycle handlebar
Wood Automotive exterior Auto part Gas Metal
Automotive tire Plant Wood Circle Gas
Wood Gas Engineering Machine Electrical wiring
Wood Gas Automotive wheel system Circle Musical instrument
I got it all but back together and I had to put it on my Cub 1811.
Tire Wheel Vehicle Motor vehicle Automotive tire
Tire Wheel Motor vehicle Automotive tire Tread
I'm anxious to try her out this spring when the ground thaws out! I've never plowed before so I've got the owner manual for the plow and I'll read it more thoroughly when I need to get it set up.
One question that I do have for those people that own this same type of plow.
Does this piece of rod that is welded in-between the beam belong there????
Automotive tire Tire Bicycle tire Bumper Wood
· Super Moderator
Nice job fixing it. My plow has that rod welded in there.
[sharedmedia=core:attachments:151680]
· Registered
My Brinley plow has the same rod weld in the same spot
Mine has a different gauge wheel but other than that they look the same
Plant Tire Wheel Wheelbarrow Wood
Wonder if the welded top link was repaired cause the Cat 1 tractor broke it off when it got caught on something.
These plows don't look heavy enough for those tractors
· Super Moderator
If you want to make a new piece for that mast, I made a drawing of the parts.
· Registered
Take a close look at the shoe (frog). Mine was also pulled behind a big tractor and the shoe was bent. It took a lot of work with a torch and big hammer to get it back to a useable shape.
Pay close attention to the adjustment instructions and take wrenches you need to make the adjustments in the field. First time out mine fought me like mad. I made some adjustments at home and 2nd time out, after some minor field adjustments, it was like a hot knife through butter.
Some of my problems though were due to the goofy nature of the Speedex 3 point. I think with your hitch it'll be easier to get right the first time.
· Super Moderator
I have a Sears 3-point here that is bent real bad in the 'frog' from use behind a Cat-1 tractor. Going to try to bend it back one of these days. May have to buy a new one.
  • Like
Reactions: Mark 149 J.
· Mark J.
Discussion Starter · #8 ·
thanks Kenny!
The rod on mine still had some mig wire sticking out from it and the welds didn't look so good. I thought maybe the PO had cut it from the cuilter shaft and used it to add some strength to the beam.
  • Like
Reactions: KennyP
· Mark J.
Discussion Starter · #9 ·
That's what I thought as well.
· Mark J.
Discussion Starter · #10 ·
Thanks!
I added that to my tractor file on my computer! Might need that in the future.
  • Like
Reactions: KennyP
· Mark J.
Discussion Starter · #11 ·
Thanks for the suggestion!
When I looked it over last night I didn't notice that is was bent but being pulled by a larger tractor anything can happen!
  • Like
Reactions: KennyP
1 - 11 of 11 Posts
