6hp briggs on lambert 666
175 Views 3 Replies 2 Participants Last post by  Dotcomdz
The issue I have is what appears to be an unsuccessful attempt to swap a carb from another engine. So none of the linkage lines up. Would some one know of an original carburetor to be found for that briggs Era? I can't find a number.
See less See more
7
  • Like
Reactions: 3
1 - 4 of 4 Posts
Idk how they even thought a breatherbwould fit the neck is up against the shroud
  • Like
Reactions: 2
I may be mistaken, but I don't think your problem is that the carburetor is incorrect. ...There is red paint on your carb, which means it may have been from a different engine, but I believe it is correct for your engine.
That throttle linkage attached to the shroud appears to be parts from a Tecumseh engine.
Any B&S Model, Type, and Code numbers were probably stamped into the shroud. ....Most likely to the left of the decal above the cobbled-up throttle linkage. ...Another possible location is at the top of the shroud above the 6hp decal. ....It appears the white paint on the engine was a repaint, so the numbers are probably under the paint.
Here is a Parts List for a 6hp B&S. ....Your engine numbers may be different, but this should give an indication of what the correct throttle linkage probably looked like.
https://www.gardentractortalk.com/d...d39690a6f44eae9d94ca0a-143300-ms4807-0188.pdf
See less See more
  • Like
  • Love
Reactions: 2
Thank you so much. Yeh looking at it there is zero way to attach govenor the 3 points of connection are all opposite, and in less than two inch movement area 😂🤷 with a hand fab throttle on carb 1 hole
  • Like
Reactions: 1
1 - 4 of 4 Posts
