I started another thread recently about throttle adjustments. Well that made a little progress until I rotated my governor pin (that may be wrong part name) counterclockwise. Well mine never stopped and now rotated freely with no endpoint. I am sure I broke the tab off the pin that causes it to stop and the governor to limit engine speed. Now while running the govenor does not function.
So I'll be taking it somewhere to have it serviced. As much as I would like to dig into this problem, lack of time and my inexperience lead me to having a professional repair it.
I am assuming the engine has to be torn down to complete this repair? This engine did not smoke originally. Is there anything else I should ask them to do while undertaking this repair?
Clean engine block rust, replace rusted bolts, replace rings, de carbon, replace gaskets, etc?
If it is going to be torn down I would like to have whatever may be needed in future done to it so it will be reliable.
Should any repair shop be able to do this? Should I look for a tractor or small engine/lawnmower shop? Any suggestions for one around me, I'm in North alabama and would drive a couple of hours to get to right place if needed.
Thanks for all your help and advice. It has been a fun learning all that I have and am so much happier with this tractor when compared to my zero turn. Awesome machine.
