1 - 6 of 6 Posts
This issue has been present for a while, just now I am addressing it. The steering wheel pops off the "steering shaft" whenever any force is applied to steer the tractor. The first pic is when the wheel is still on the shaft, the second and third pic is when the wheel popped off.
Sent from my SM-J327V using Tapatalk
Fixer of Broken junk
Cub Cadet part # 941-3023
It's just a nylon bushing. I have a 127 that has the same problem but the 127 should have a dense foam spacer between the bushing and steering wheel which is supposed to keep tension on the bushing.
On the 782 It's supposed to have a rubber O-Ring (Cub Cadet part # 721-3000) between the steering wheel and the bushing to apply a bit of tension. That bushing is around $5 and the O-Ring is $1.75 online.
Discussion Starter · #3 ·
Thanks for the info, I'm gonna try to get that fixed soon.
It kind of looks like your wheel raises out of the tub when it is turned. If this is the case then you need to address your steering box. When the steering box is warn it will allow the steering shaft to move up when you turn the wheel.
Discussion Starter · #5 ·
Well I was thinking that was the problem, but I can't move the steering shaft up or down at all.
Discussion Starter · #6 ·
Steering is fixed. All that happened was the steering wheel wasn't tightened down and the plastic bushing came out of place.
1 - 6 of 6 Posts
