Vapor lock.
That's what it sounds like to me.
Sent from my SM-S205DL using Tapatalk
Yes, does sound like a carb issue. Could be a plugged fuel line or filter.I can get a whole new carb for 24 shipped, I will likely do so just to remove that out of the equation. Carb on it is original and likely older than I am.
You changed quite a few items, it definitely sounds fuel related, what about the fuel filter? when they are clogging it will let gas go through for a while and then plug up, when the flow stops the sediment falls to the bottom and you are then able to restart and run until it does it again. If you have one take it off and tap the inlet side on a table and see what comes out.I have a vintage International Cadet 75 rear engine riding mower with an original Briggs and Stratton vertical shaft 7hp engine. Its my main workhorse mower and been using it solidly for about 3 years now.
I have been trying to track down a weird problem where it will start running rough and die after 20-30minutes of solid mowing.
Wont restart unless choke is fully open and immediately dies if throttle is lowered below full choke. If I wait 5 minutes it will start and run again like normal without choke. I get maybe another five minutes of mowing, and it will die again.
I noticed it seems to be related to heat. If I run the mower extra hard, it will do this more often and quicker. Sometimes if I leave the throttle lower and mow in a lower gear putting less load on it, it will be OK.
Blew out the cover with air compressor. Still happened.
Replaced ignition and spark plug. Still happened.
Changed gas cap, also tried leaving it cracked oepn. Changed oil, seemed to go longer but still happened.
Suspected starter clutch hanging and disconnected the top from it. No change.
Adjusted carb to be less lean, seems to happen earlier.
I noticed randomly that really bumpy ground will make it sometimes missfire a bit and can sometimes start it on the path to dying like this.
Got a spark tester and left it on the mower. Spark is identical before and after. I see sparks when its cranking right after dying and wont start.
I am thinking next maybe to check compression when running and immediately after it dies to see if a valve is sticking or something?
Any ideas….
Briggs 170707
Type: 1198-01
Code: 73041311
Any ideas….
Definitely check compression hot.
I found most of those old small engines would not run if compression less than 60 psi
Briggs 170707
Type: 1198-01
Code: 73041311
I would be a bit suspicious of that fuel valve/nipple on the carb. I would unscrew it from the carb and see how much gas flows through it to get a better idea of how much is getting to the carb.I thought about making a plate to shield it but its really not that close the photo angle just came out that way. Its nearly 6 inches above it.
I have a few other of these and already changed fuel lines. Its just tractor supply International Harvester White. Other mower it came off of was repainted by the guy before I got it.
I suspect the governor honestly. Seems if something makes it bog and drop rpm the throttle doesnt try to raise up as high as it was.
But yes I have tried everything so I will put some foil around it for the next try.
