While waiting for some plastic sheet to arrive so I can finish the snow caster project, I am going to do some tinkering on the tractor that the caster is going to be mated up with for the winter. This is the tractor I stuffed a Kohler V-twin motor in a couple years ago. Maybe I should call it an H18? There were a couple of issues right off the bat when I first started using the tractor 2 winters ago, but they were easily remedied. Had a carburetor issue first and then it dropped an ignition coil. I simply replaced the carburetor and both coils. It has run great ever since. The motor was liberated from a Cub Cadet. I'm very pleased with the tractor as it almost makes it a joy to go out and blow snow. It was a big improvement for me instead of using one of the gear drive tractors with a manual lift. I do a lot of clean out in close to the house and garage and am constantly changing direction and having to lift the caster to maneuver. This tractor makes all that much easier. The first thing I decided to look at was the linkage for the hydro control. I had put a couple springs on the linkage bar to replace the rusted ones that were there when I first repowered it. The tractor has been touchy when doing speed or direction changes and I figured the springs were too weak. I dug through my collection of springs and found some possible substitutes. The two wimpy springs I removed are at the 6 o'clock position in the tray. Lady Luck must have been smiling down on me today as the first pair of springs I tried worked well. I did try tweaking the adjustment a bit and think I found the sweet spot. Yay!! That was it for today, I have a few more things I'm going to look at
