1 - 9 of 9 Posts
Hi guys,
so I have my 1254 ready for snow, mostly. I had to start it up yesterday and it started very hard, and I don't want to mess with that when I gotta move snow. I did adjust the carb a bit and that helped, and I have to try it again today so I'll see how much it helped. Is there anything else I can do to make it start easier? Also, I replaced the head gasket recently.
Also, I am thinking about making a weight box for it for snow plowing. How necessary is that? I have the tires loaded, and at least 100-150 lbs of weights on the wheels. I weigh about 180, and it's got chains. Is that enough?
When you adjusted the carb was it on a cold engine or after the engine warmed up? Adjustments need to be made when the engine is at operating temperature otherwise you'll never get it set right.
I have been plowing with mine since 2010 and have no troubles with chains, stock tires and weights. Anything other than that is overkill in my opinion
Re learning the Choke procedure?? I have some tractors that need to be choked, but don't start till the choke is pushed in all the way and then has to clean itself out running a minute. OR, 1/2 choke? More choke if you don't use in warm? Have to experiment to try diff things. Wisconsin? don't they have record of being hard to start? Thought I heard that.
Discussion Starter · #5 ·
The engine was warm. It wanted to die when I pushed the throttle all the way in, so I gave it a little juice on the needle. It seemed to start OK today, my main problem is that my belt is a solid belt. Brian, do you have any starter belts for this?
Good to know on the plowing setup! It sounds like I'll get to test it out tomorrow!
Where is it stored? Garage? Heated garage? Outside?
It's stored in our pole shed, unheated.
This one is pretty straightforward, choke all the way out, even after it starts. Then when it starts to sound rich and choked out push the choke all the way in and it runs perfect.
1 - 9 of 9 Posts
