1 - 3 of 3 Posts
Ok so I'm appreciating all the input you guys are giving me on my lawn mower situation My ariens I'm helping me to learn this this is a great site I love it and I have a tiller on the back of it and I'm needing to try to figure out why it will only go up and down a little ways any suggestions for help will be greatly appreciated thank you
401297
401298
It only needs to go a little above the ground. When you start tilling, it will go a lot down into the ground. Doesn't the mower deck get in the way when tilling? Good Luck, Rick
Does your mower lift? I am guessing that when you switch from front to the rear lift, that the bar that pivots to lock the cylinder isn't latching. The little bit it drops is play in the linkage. With it in the up position, you can slip a finger in right above the cylinder and manually flip it. I have to do that to mine to switch to the rear lift, but not to the front.
1 - 3 of 3 Posts
