1 - 11 of 11 Posts
Just got home with my newest toy, another Ridemaster. I responded to an ad for Ridemaster attachments and ended up buying all of his attachments, a spare engine, and his tractor. The tires were flat and dry rotted when I got it and he said the carb needed cleaned. I pumped up the tires at a service station on the way home and they held air. I got it running when I got home, but it runs a little rough. I will need to rebuild the carb. It was restored about 10 years ago. The colors aren't right and I will freshen up the paint in the correct colors. On the whole it is in good spade and I am very happy with the purchase. I unloaded it and put it in the barn under it's own power. On the way home we saw antiques roadshow was at the farm show complex in Harrisburg, PA. I was so tempted to swing in and see what their experts would have to say, but I just wanted to get it home. IMG_1154.JPG IMG_1155.JPG IMG_1157.JPG My son obviously approves of the new addition!
Great thing besides getting it, is it should be easy to take apart!
Premium Member
How does the sickle bar attach to one of those?
Hangs under the front and runs off the pulley on the front of the engine.
Premium Member
Put in a new spark plug and adjusted the carb and got it running better. I put the discs on and disced a section of my garden before I plant. What a fun tractor to drive.
They sure are fun to drive!! Glad you got her running better.
  • Like
Reactions: Tbrooks
Discussion Starter · #10 ·
So last night when it was running, it would run smooth under load but when I put it in neutral the engine would surge or hunt. The previous owner told me before I bought it that he felt the carb needed cleaning. I decided tonight to do just that. As I was stripping it down I found the source of most of my problems, I think. It looks as though someone has had hand filed a point on the high speed jet. The point is not concentric to the shaft and the taper is not even ad has small flats on it. I had a new jet on the shelf. I am leaving it soak in carb cleaner over night and I will put it back together tomorrow and see if it will run better.
1 - 11 of 11 Posts
