1 - 6 of 6 Posts
The tire specified is a 23x8.50x12 . If you can find an HONEST sized tire, that would probably do the trick. I briefly tried a 24x12x12 tire on my Massey 12, but the sidewalls rubbed on the seat pan. I have a 25x10x12 ATV tire on currently, and I'm not sure the deck would fit. I'd say that if you are set on installing the tires and the deck at the same time, you need to stick to stock tires.
  • Like
Reactions: ARTmf12 and JRJ
In my confusion whats the bigest ag tires will fit a mf 12 with a mowerdeck on THANKS ART
Hi ART.
Just in case I missed your introduction, WELCOME TO GTT. :wave:
Nice to have another MF guy around here.
As the guys said, there isn't a whole lot of room to play around
with on the MF10/12. You pretty much gotta stick to the size's that
they spell out in the manual.
Unless of course, you want to do some custom stuff, and raise the
fender pan, and put some big honkin AGs on there.
Either way, we'd love to see some pictures.
Discussion Starter · #5 ·
THANKS as soon as i get her together i'll get some pic's up ......and find my last part........art
If you're using the factory offset wheels for the 12 the biggest you can go is 23-10.5" wide,but not the tru 10.5 tires.Depending on which tires you get they have different widths.They are supposed to be 10.5,but are actually only 9.5" wide.The ags I have on my 10 are marked 10.5 but measure 9.5 and fit good. .Check with the tire manufacturer on the actual width.
1 - 6 of 6 Posts
