I could use some help. I have a Agway 2125 12.5 hp tractor. I am having problems starting it. it has a brand new battery but it acts like the battery is dead. When I try to start it either nothing happens or it wil make one revolution but will not turn over. I have started it by hooking my jumper box right to the starter. Any help would be appreciated. Thank you..
Welcome Aboard. Pretty bold user name. oke: From your description I would suspect the starter solenoid, but it could be wiring or ignition switch. Have you tried jumping across the solenoid? What is the make of the engine?
Welcome to GTT. You are going to have to do some electrical diagnosis. The first suspect is a bad or intermittent ground. The second is a loose or corroded electrical connection. If checking and cleaning connections doesn't fix it, take some pics and post them with a description of what it is and isn't doing. Good Luck, Rick
ok... I have worked on it a little more. I found that if I pulled up on the blades past them being disengaged it started a couple times but a couple times it did the same thing. i could not get it to start at all before pulling up on the blades. it still does not start all the time while holding the blades up, also if i pull the plug out it will turn over like there's nothing wrong, when put back in it acts like it did before. Thanks in advance for the help...
Ok. im lost. lol.. I have an interstate 12v battery in it. reads 12.0 on my meter. I hooked up my jumper box right to the battery and it started right up without holding the blades up. took the jumper box off put my meter on it while it was running 12.8v. turned the tractor off would not start meter reads11.0... the starter jumps up and it acts like it wants to turn but wont. I did forget to mention in my earlier post that i had the tractor hooked up via jumper cables to a huskee battery that I just bought when I had it started earlier. Thanks again in advance
ok. I cant install the huskee battery because it wont fit. I did some research and found that the battery that is in there has lower amp hours then mtd recommends. I tried jumping with the battery and the same thing. the starter jumps up but will not turn over. It will turn over like that with the jumper box. Thanks again for all the help
If the engine in that thing is a Briggs & Stratton it may be time for a valve clearance check/adjustment. The B&S 'compression release' is a little bump on the cam.. If the valve clearance is wrong the C/R will not work correctly and what you are describing is the result of this.. Hard cranking.. Just a thought for ya
Have you done the suggested tasks? We start from the easiest fixes first, trying to narrow down the issue, before going out and buying parts.
