1 - 16 of 16 Posts
Hi Everyone. I have a 1968 Allis Chalmers B-112. I am in the process of restoring this tractor, however it is in use now and runs great. Has saved my but this year with the 3 feet of snow we just got here in NY over the last week. I am looking for a list of things i will post here. If anyone has these items please contact me and we can make arrangements to buy them. I will remove items as I get them so if its listen on here I still want it. I have been able to stay with all original parts and implements so far and wish to continue to do so.
I understand that some of these are not specific to the B112 so when i say B112 in the list I just mean B-series part.
Wanted:
-B112 rear 'stinger' counterweight and donuts
-B112 original lights and mounting brackets
-Sweepster Attachment
-post hole digger
-42" Rotary Snowblower LIFT ROD
-hood "thumb screws"
-B112 Hydraulic Unit and all needed associated parts
-any b-series attachments
Thanks for your time.
will have updated better pics soon. pretty much restored whole tractor now mechanically. shes blowing massive amounts of snow 30 feet or more at times! awesome tractor. new paint and decals this spring.
:wave: Welcome to the forum! Nice lookin' AC you have there!
  • Like
Reactions: ACB112Guy
Summer.
Welcome to GT Talk, that is a nice Allis you got there, they sure do throw that snow, solid workers.
Some of the members may have some of the parts you need.
  • Like
Discussion Starter · #5 ·
Thanks guys! looking forward to this forum and meeting more of you guys. Not too many people near me into Old Garden Tractors, so this surely is a great place and resource i found. Thanks again.
Premium Member
Welcome to GTtalk, There are quite a few members up in that area. I was just up there last week in Lee, MA. working. Check out our Members Map and you will see where most everyone is located at.
  • Like
Nice!! I have one just like it, On e-bay rite now is a complete 112 parted out. the lights are there but they are in rough shape. I do not have any original parts I am willing to part with but I do have some 1" thick steel burnouts that fit just inside the rim, they set on the beadlock surface, probably 40lbs each. I would sell a set for $40 drilled to fit. they don't look like much but they get the job done.
Discussion Starter · #9 ·
I rigged it up with some heavy duty cable which works great. from my research which could be wrong since im a beginner is that there is a lift rod. but im only going by one of the parts diagrams for the 42" rotary snow blower.
I have a 1" pipe with some tractor weights setup, appreciate the offer. I just want the original. I missed it (stinger oem counterweight) on ebay earlier this week by $1 dollar. i should have bid higher. i learned my lesson.
I think I saw those lights petrrj6, they are a little rough. I was thinking about it, but im hoping to find something slightly nicer if possible. I may buy a two b112 tractor deal i found which has one hb112 so i can get the hydraulics and one manual lift b112. comes with two decks, plow, and the tiller. talked the guy down to 450 for all which is a heck of deal i think, but i have to find a way to get them. its about 400 mile round trip for me and the only truck i have access to wont cut it. might rent a truck.
the lights can get very expensive, I got a killer deal on a set in real nice shape for $80 plus ship over the summer. I have seen them go for over $150. As for the lift bar I only know what is on my tractor, been that way since I bought it, I can see how it would be very easy to bend the bar when blowing snow, $450 for two tractors sounds like a good deal, if you get them I would be interested in one of the 48" deck's.
FYI I just want to give a bit of advice about the hydraulic lift, I have one on my b112 and tried to use it in the spring for tilling, the lift has no rapid float, it will float but it does so very slowly only as fast as the fluid can be forced thru the pump. so when you are blowing or tilling and the hitch needs to go up or down rapidly things will bend, I am rebuilding the variable speed drive on my 112 and have to take the rear lift bar out of it to straighten it.
Steve B, nice to meet you. I think the side panel you need is on ebay. I will have to look again. is that the simplicity blower? I see you have a lift rod on that one so just wondering if you know more about the blower. looks exactly like my ac 42" rotary blower, except im trying to figure out if im missing the lift rod or if it infact does use a chain/cable lift. I really think its a lift rod as you have there. but my cable is working quite nicely.
Hi ACB,
Yes my blower is a Simplicity, It is the same as the Allis. It does use a lift rod. The rod is 25.5" long. It is bent to a J hook on the top end and the bottom is threaded for about 1.5". It has a clevis on the bottom to attach to the plow. The rod is 5/8" in diameter. I can send close up photos if you need them. Watch out for the Ice Tomorrow!
Steve
1 - 16 of 16 Posts
