1 - 1 of 1 Posts
Similar to Simplicity Broadmoor
'71 & '72 models have slightly different frame, drive belt/clutch configuration, and transaxle than '73 & '74 models
8hp vertical shaft Briggs
belt drive with tensioner style clutch
Simplicity designed 3+1 speed transaxle
solid mounted front axle with a center pivot point in frame
Images
Wheel Tire Vehicle Automotive tire Motor vehicle
Model Number:1600264
Engine(s) Used:190700
Drive Type:Manual
Transmission:Simplicity 3+1
PTO:Rear, Mid Mount
Mid Mount Mower Size:36"
Production From:1971
Production To:1974
Rear Lift:N/A
Original Selling Price:970
Weight:360
Length:58"
Width:32"
Wheelbase:41"
Front Tire Size:5.30 x 4.50 x 6
Rear Tire Size:18 x 9.50 x 8
Brake System:Band Brake
Electrical Ground:Negative Ground
Electrical Voltage:12V
Belt Sizes:
Footnotes:>available attachments: 36" deck (1600266), 30" tiller, 42" dozer blade (1600293), 32" snow thrower, 40" grader blade, vacuum collector, 26" lawn revitalizer (1600137), dump cart, 31" lawn sweeper
available options: rear wheel weights, tire chains, hub caps, rear frame weight, light kit (1690041)
1 - 1 of 1 Posts
