I purchased the correct thickness aluminum sheet, sheared the plates to the correct size ( same as the original I.D.plate ) . Jigged the hole punch to put the correct size and location hole in each corner then filed the notch in the bottom edge . That was the easy part ! Next I contacted a local silkscreen printer and had them produce an exact reproduction of the printing on the plate . Then they printed it onto the aluminum plate and now all I have left to do is procure the correct size metal stamp set and transfer the serial number and spec numbers over to the new plate . I saved the original three-eared fasteners that were on it originally but am considering using 1/8" pop rivets instead . I'm also making sure that the throttle and choke cables don't come anywhere near the new plate . And yes, I did make extra plates if anyone's interested . It just takes time and patience and lots of money !
