1 - 12 of 12 Posts
Been having a blast tinkering and fixing the prev owners feeble attempts to keep the old girl running..
The 1556 seems to be ready for winter... One thing I noticed is yesterday I had the trickle charger on it,, and it read charged,, I needed the extention cord for awhile for another project, When I went to plug in the charger again It showed it was charging.. It has been on for about 8 hrs. now and and still no full charge.. NOW,, other than the batt. not being the greatest, or not new..Is there places on the tractor that I can check for Amp draw with every thing off ?? and if so what's the best way to go about it ? Should I use a test light or ohm meter ?
What wires on the start switch are hot all the time
would any of the switches be able to draw amps ? with the key off
If I used a test light, and put it on the ground,, then checked for a hot wire would that work ?
I read tinkerers thread about ELEC 101 ( which was exellent by the way ) But read nothing about checking for amp draw..
Any thoughts on this or help would be app. Thanks sodi
old member
sodi
easiest is to use a test light, dis-connect the ground from the battery connect the test light between battery ground post and the ground cable. if the light lights, something is drawing current. then start dis-connecting wires from the positive side until the light goes out.
Amperage has to be measured with an ammeter. It shows how mush power is being used by an electrical device. Wattage is the heat/energy that is being displaced by a device and voltage is the number of flowing electrons to create the power.
Using a test light will only show a completed circuit where an ohm meter will show the amount of resistance within the cicuit.
I believe you meant to title your topic as Completed or open electrical circuit. That's all you can do with a test light and multimeter.
Freedom is not Free. Thank those in uniform for yo
MyBolens1053 is correct. If you think you have a draw on the system take an ammeter and clamp it around the positive cable off the battery it should show zero it if does then you need to start looking.
But if you are going by a battery tender then I would first reset it and see what happens. I keep one on my bike all the time. If I move my bike and unplug the tender it then plug it back in it will show charging again but I'm not sure how long it takes to show fully charged again. Also make sure your fluid levels are correct if you haven't already done so.
Bud W has it right when he says to connect the test light between the cable and the battery. If the light is on, there is amperage flowing through the circuit. I use that test all the time.
An Amp meter will give you the best readings if you place between the positive cable and post on the battery. Most Multi meters have this capability but are only protected to 5 Amps. If the draw is more then that, it will blow the fuse in the meter to protect the meter. I once spent a few days working on a friend's car that would have a dead battery if it set for more then 3 days. Turns out the reverse switch on the trans was bad and had a short in it enough to allow 0.3 power thru it to the back up lights. That wasn't enough to even make the filament in the bulb turn orange, but would drain the battery in a few days. Good luck and let us know what you find.
All good info here and Brian makes good point about the internal fuses in the multi meters (using it inline not using with an inductive clamp ) , I know that for a fact they blow quick :wallbanging: I'll start with a test light first and it it lights , will start there if not then switch to a multi meter at the highest Amp setting , mine has 2
A parasitic load like that won't kill the battery very quick. I've seen mine to where the filament was just barely glowing. It just looked like an orange thread.
If you suspect a trickle loss of voltage happening. take an ammeter and a wire long enough to wrap like a spring 10 times and reach the positive battery terminal and its place of contact. The wraps in the wire multiply the magnetic field by 10 and should give you a better reading to go by.
1 - 12 of 12 Posts
