1 - 14 of 14 Posts
Done of the 446, so I’m going to move on to the snocaster for the 224.
This snocaster was sitting outside, along with the tractor, for about 5 years, before I got it. So every thing is seized. The little bit I’ve looked at it, nothing moved. So will see if I can get it operating, and if so, the mower deck will come off the 224 and snocaster will go on. Then the next thing to do, is a quick fix to the mower deck. Mowing will be here before you know it. Hehe.
So hopefully next week I’ll get the caster on the bench and begin. NO painting on this one.
Noel
A Little Off Plumb
Look forward to seeing how this one turns out for you. Hibernation appears not to have set in yet.
Discussion Starter · #4 ·
Got most things loose today but needs a bit more work. Auger moves. It needs a lot of lube here and there. Going to clean out auger tube. Full of dirt, same as the other one. And I’ll fill it with oil till it starts to run out either end. And will pack bearings. The chute and universal for the chute crank were not stuck. But need lubing. Any way, it’s a start.
Noel
Discussion Starter · #5 ·
A little more done today. Auger is out. Cleaned the dirt out of the auger tube. Packed grease in the bearings. After I got the auger out I was able to get the chain apart. Chain is rusty and very stiff. I have another old chain so we’ll see if the rusty chain will work out. If not may use the other old one. Still have one stuck pulley yet.
Noel
Discussion Starter · #6 ·
More done today. It’s coming along good. All seized parts seem to be working good. Will see how it goes when working. It may not get much use, any way. Why buy new parts if ya don’t need them. I like to fix things. I will do what I can before I buy parts. Used or new. Any way. That’s just me, learned from my father.
Have a good day members.
Noel
Discussion Starter · #7 ·
Gear oil in the auger tube. New parts so far are the connector link and a cotter pin. Which I had. Kinda hard to fix or make those parts.
All the parts I’m pointing to were seized.
Noel
A Little Off Plumb
Nice job on getting it so everything would turn again. Now all you need is 3 feet of snow to test it out???
Discussion Starter · #9 ·
That’s all right Stew. I’d rather sit in the garage with the wood stove on and let you have all the snow, then you can have all the fun.
Noel
Discussion Starter · #10 ·
So did a little painting, somebody was wanting me to paint. Any way, the caster only had one homemade skid on it. Talked with the fella that I buy small engine stuff from and he could fix me up with skids. I guess most skids are 3” centre to centre for the bolt pattern. For some reason Case casters are 3 3/8” centre to centre, so would have to modify some thing. Then I figured, why buy skids, I could make one similar to the other homemade one. So that’s what I did. Found some old metal and made one. Have to adjust them once the caster is on the tractor.
The other thing I did was was cut another notch in the chute so it will turn farther each way. Did that to the other caster on the 446 too.
And finish putting other stuff back on, so it’s basically done now.
Also got the 1/2 link out out the chain and it’s adjusted good now, with lots of room to adjust it when needed.
Noel
Discussion Starter · #11 ·
There now, another Case project done. Got the mower off and snocaster put on the Case 224. Every thing works. So that completes the snow fleet for this year. Well not quite, still have chains and maybe weight to put on the 224 yet.
Any way, next thing to work on is when one of the any 5 snow removal machines breaks down. And that could be on the first snow fall.
Noel
Discussion Starter · #12 ·
Found a little bit of weight for the 224. 40 lbs. I put that on. Would like to have more. Hard to find any weights at a reasonable price.
Noel
  • Like
Reactions: IHCubCadet147
A Little Off Plumb
The weight will probably come in handy until you get some chains on. If you could find some old (or new) frisbees, aluminum pie plates or similar you could put a short piece of pipe in the center (that would fit over your round bar) and then fill the outer area with mixed quickcrete cement - would think one bag would give you about 7 or 8 weights. Level the cement off with the top of the dished area and then once the cement has hardened you could poke a hole in the sleeve and mount it on your bar. Just a suggestion - bag of quicrete goes for about $7.00 around here..
1 - 14 of 14 Posts
