1 - 6 of 6 Posts
The differences are usually in the oil pans. Not ever owning M/F, I can't tell you which one you need.
  • Like
Reactions: Clippnalawn
Nut Case
You can swap the oil pan from your blown engine to the rebuilt one if need be.
Eric
Sent from my SPH-D700 using Tapatalk
I ran into the same issue with my mf16. I thought I could use a k341 from a cub, or at least swap the pan like others have suggested....the oil pans bolted to the block completely different. Long story short I had to rebuild the massey engine.
Electric Tractors
I have bought 2 rebuild kits for the K341, they come with 2 different oil pan gaskets in each kit, looks like the bottom of the blocks come in 2 different styles.
  • Like
1 - 6 of 6 Posts
