1 - 14 of 14 Posts
So i had to make a run to the Hartford CT area today so like any other good tractor hunter i searched the local Craigslist and snatched this H16 with round back. Surprisingly it runs and moves hydro makes no noise and has been converted to a spin on filter already. The tractor and blower need work but i'm ok with that i was mainly after the round back blower the H16 was kinda a bonus.
A few pics i grabbed between the rain tomorrow im going to power wash it and get it stored away.
With ag tires. Bonus too. Noel
Premium Member
Not a bad looker nice buy.
Discussion Starter · #5 ·
Thanks everyone it's needs some work but i feel this is a perfect size tractor to me plenty of snow blowing power and hydro for mowing duty.
sadly not the left side rim is rotten with a hole and the good year ags are shot :(
Gee nice set up there. The mower deck looks awesome.
Dug out the power washer and cleaned my new prize. It's going to need some work before it will be dependable but i feel this one is worth it. If anyone in my area is interested in the deck let me know i have no use for a 42" deck gonna need paint and rebuild.
Things wrong i noticed
Steering slop needs tie rod ends (2)
Drag link
needs a new pivot pin and bushings
plastic bushing under steering wheel
the rod for the idlers is bent causing them to both ride screwed up.
wrong spring for drive belt tension
needs new belts for the drive and pto
the bushing for the hydro pedal is gone
rear rims rusted from calcium (i have a new set already)
front tires shot (i have 2 new tires)
rear tires (gonna go with 23x8.5-12)
tune up plug,oil,carb rebiuld
seat
paint
Is this hose correct?
Pulley miss alignment
Discussion Starter · #13 ·
I have another question are these supposed to have a reservoir for the hydro system. Also how do you go about doing a hydro service on these?
Only the early serial numbers of this model had the reservoir tanks on them. I think the big filter took the place of the tank n the later serial number models. The medium Tubeframe service manual should go over servicing the Hydro unit.
1 - 14 of 14 Posts
