1 - 11 of 11 Posts
Premium Member
Some of you may have heard me mention that I am chasing a squealing sound in my mower deck on the Massey MF12. I took the belt cover off yesterday and checked belt tension and the belts and they all seem to be in good shape still. I also checked the pulleys and they seem fine as well. So I left the belt cover off and went and tried mowing again and as soon as I put a load on the deck is when it starts to make the sound. It is coming more from the right then the left.
Fast rewind to last summer when I got the tractor I bought brand new blades for the deck and I removed and installed the new ones with a 1/2" impact gun not knowing about the belleville washers.
I checked the manual for the mower deck and here it mentions in there about the washers and not torquing them too tight as it will make the washers eventually slip.
I think this may be my problem. Which is why I am asking if anyone else has had this happen and if they found any other sources for the washers or if I can get them from tractor supply or some other hardware source rather then the dealer.
Hangin' with the cool kids
Ontario, Canada
No idea...I rebuilt my MF10 deck last year, bearings pulleys, belts......Maybe, I just got lucky......I didn't mpact it back together however.
Electric Tractors
I've seen 2 different types of blades for these decks, 1 has a round hole, the 2nd has same size hole but 2 flat sides on it. The 2nd style with the flat sides I can't see how that would slip as the spindle shaft is the same way. The 1st style with the round hole that would slip if there wasn't enough pressure on the rubber washer to hold it. Had this problem with 1 of my decks and put an extra washer in to apply more pressure on the rubber one without touching the spindle shaft.
Premium Member
Discussion Starter · #4 ·
Doug, you know now that you mention it I seem to remember mine having flat sides on them. I will have to pull the blades off and look. This is going to drive me nuts till I find the source of the squeal.
Electric Tractors
Pictures of Massey blades.
All the spindles I've seen are made with flat sides, I have 3 good deck housings and at least 15 spindle assembly's.
Also a pic of those 2 little cover plates.
Could be the blade slipping. If there is much wear, the washer might be dead ending against the shaft before it can apply enough pressure. If the shaft protrudes above the blade, even ever so slightly, then it's the squeal source.
Electric Tractors
Exactly that's the problem I had on 1 of my decks, noticed it was loose when putting it together so I put in an extra washer big enough to go over the spindle next to the rubber and it tightened right up.
Premium Member
Discussion Starter · #8 ·
I will have to dig in to it tomorrow. It just sucks right now till I either sell my pickup or we move I have to pull all of the tractors outside to work on anything and usually it takes me longer to fire them all up and back em out then it does to work on whatever it may be.
G
Probably more than you wanted to know:
Design and use
Belleville washers are typically used as springs, or to apply a pre-load or flexible quality to a bolted joint. Belleville springs are also used in a number of landmines e.g. the American M14 and M1 and the Swedish Tret-Mi.59.
They may also be used as locking devices, but only in applications with low dynamic loads, such as down-tube shifters for bicycles. Belleville washers are seen on Formula One cars, as they provide extremely detailed tuning ability. At least one modern aircraft design, the Cirrus SR2x series, uses a Belleville washer setup to damp out nose gear oscillations (or "shimmy").
Another example where they aid locking is a joint that experiences a large amount of thermal expansion and contraction. They will supply the required pre-load, but the bolt may have an additional locking mechanism (like Loctite) that would fail without the Belleville.
[edit] Stacking
Multiple Belleville washers may be stacked to modify the spring constant or amount of deflection. Stacking in the same direction will add the spring constant in parallel, creating a stiffer joint (with the same deflection). Stacking in an alternating direction is the same as adding springs in series, resulting in a lower spring constant and greater deflection. Mixing and matching directions allow a specific spring constant and deflection capacity to be designed.
Example: 1 Spring is considered to be 1 in Parallel, 1 in Series. (This notation is needed for load calculations)
If n = # of springs in a stack, then: Parallel Stack (n in parallel, 1 in series) - Deflection is equal to that of one spring, Load is equal to that of n x 1 spring. i.e. Stack of 4 in parallel, 1 in series will have the same deflection as that of one spring and the load will be 4 times higher than that of one spring.
Series Stack (1 in parallel, n in series) - Deflection is equal to n x 1 spring, load is equal to that of one spring. i.e. Stack of 1 in parallel, 4 in series will have the same load of one spring and the deflection will be 4 times greater.
[edit] Performance considerations
In a parallel stack, hysteresis (load losses) will occur due to friction between the springs. This loss due to friction can be calculated using hysteresis methods. Ideally, no more than 4 springs should be placed in parallel. If a greater load is required, then factor of safety must be increased in order to compensate for loss of load due to friction. Friction loss is not as much of an issue in series stacks
In a series stack, the deflection is not exactly proportional to the number of springs. This is because of a bottoming out effect when the springs are compressed to flat. The contact surface area increases once the spring is deflected beyond 95%. This decreases the moment arm and the spring will offer a greater spring resistance. Hysteresis can be used to calculate predicted deflections in a series stack. The number of springs used in a series stack is not as much of an issue as in parallel stacks.
Belleville washers are useful for adjustments because different thicknesses can be swapped in and out and they can be configured differently to achieve essentially infinite tunability of spring rate while only filling up a small part of the technician's tool box. They are ideal in situations where a heavy spring force is required with minimal free length and compression before reaching solid height. The downside, though, is weight, and they are severely travel limited compared to a conventional coil spring when free length is not an issue.
A similar device is a wave washer.
[edit] Calculation
2-3-1-2 stack of washers
If friction and bottoming-out effects are ignored, the spring rate of a stack of identical Belleville washers can be quickly approximated. Counting from one end of the stack, group by the number of adjacent washers in parallel. For example, in the stack of washers to the right, the grouping is 2-3-1-2, because there is a group of 2 washers in parallel, then a group of 3, then a single washer, then another group of 2.
The total spring coefficient is:
K = \frac{k}{\sum_{i=1}^g \frac{1}{n_i}}
K = \frac{k}{\frac{1}{2}+\frac{1}{3}+\frac{1}{1}+\frac{1}{2}}
K = \frac{3}{7} k
Where
* ni = the number of washers in the ith group
* g = the number of groups
* k = the spring constant of one washer
So, a 2-3-1-2 stack (or, since addition is commutative, a 3-2-2-1 stack) gives a spring constant of 3/7 that of a single washer. These same 8 washers can be arranged in a 3-3-2 configuration (K = 6/7*k), a 4-4 configuration (K = 2*k), a 2-2-2-2 configuration (K = 1/2*k), and various other configurations. The number of unique ways to stack n washers increases dramatically with n, allowing fine-tuning of the spring constant. However, each configuration will have a different length, requiring the use of shims in most cases.
George, did you ever figure out where the squealing sound was coming from? If you need the washers I have a couple parts decks, I can see if there are any good washers on them.
Premium Member
Discussion Starter · #11 ·
I have to tear in to it. I think it is either the tensioner pulley or the idler pulley. I have had a lot on my plate this weekend and didn't get a chance to tear in to it. Hopefully this week though. I will keep yas updated.
1 - 11 of 11 Posts
