First, I'm a newbee to this forum. I've joined with hopes of gaining knowledge on rebuilding the old Ariens GT17 I've recently pulled out of the shed. It was parked there 5 years ago after the engine blew up on it. Everything else on the tractor was working and appears to still be in decent shape except the engine. This is where my dilemma begins. The blown engine that came out of the tractor is a cast K341s 16 HP horizontal shaft Kohler? Now from what I've read, this tractor originally came with a 17.5 HP Kohler. So I'm thinking the previous owner must have repowered with the smaller Kohler. My question to the forum is if I can still use the 18 HP Briggs replacement with its conversion kit for the 17.5 HP Kohler, even though I have the 16HP Kohler. I guess the first thing I should do is pull the driveshaft and pto drive pulleys off the 16HP and measure the shaft. Any further suggestions would be appreciated. I normally wouldn't undertake this venture, however, after replacing the 4th busted cast aluminum mandrel on the Husqvarna deck, I've had my fill. They don't make them like they used to...or at least...not for the same money.
