1 - 3 of 3 Posts
how far should the belt ride in the rear drive pulley? new belts being installed, the old belt was even with the pulley edge, no shims inside.
Electric Tractors
I think you need to go through the whole Vari-drive adjustment procedure.
The rear Idler pulley needs to be flush to the top of the frame to 1/4" below when in park, if not add or remove shims till it's right.
You will probably have to add shims with a new belt installed.
I don't there is any set spot for the rear belt to be in because as the belt wears it changes.
1 - 3 of 3 Posts
