1 - 3 of 3 Posts
Hello I have the briggs 10 horse on my tractor, and would like to be able to get the full 16 amps out of the alternator since I have the 16 amp stator. Is there anyway I can do this. Im guessing I don't have the required larger magnets on my flywheel but not sure. I do have the 16 amp stator and regulator. Thought about purchasing a later flywheel and swapping over magnets but Im not sure that would work. I think Im getting about 5 amps now, but cannot remember, its been a while since I converted or upgraded the stator and regulator.
Freedom is not Free. Thank those in uniform for yo
Why do you need the 16 amp stator? The regulator is going to cut it down to a manageable level.
Discussion Starter · #3 ·
so 5 amps is good? As in like the batterys charged so that's all its going to output? I have the bolens headlights and figured that would load it down. The charge voltage drops when I turn on the headlights to the high 12's. When I had the original stator on it didn't keep up. I wanted the 16 amp stator because I want lights to see at night for snow plowing. Basically I want to add accessories so I went for the maximum output alternator.
1 - 3 of 3 Posts
