1 - 11 of 11 Posts
Like I mentioned on a previous post I am having a loader made for my 1250. I didn't feel like trying to make a bracket etc. for another pump so my question is can I use the hydrostatic pump (auxiliary outlet) to power the loader if I use smaller cylinders etc.?
I wish I knew someone that had pre made brackets and pulleys and I would put on another pump.
Premium Member
No you cant it dont put out the power you need to run the loader.
  • Like
Reactions: boyscout862
The Johnson loaders were run off a pump mounted to a bracket on the bracing of the loader frame. IIRC, a 4" pulley on the pump and a 4" pulley mounted between the engine flywheel and the triple PTO drive pulleys on the engine front stub shaft. Not too hard to do for someone with a welder.
By the way, very often if you find a Johnson loader that has been separated from the tractor, the pulley on the engine went with the tractor anyway, so you still have to find a pulley. For mine, I had to find a 4" cast pulley, bore the center for the stub shaft, cut a keyway in the bore, drill and tap two set screw bores, and shave one face of the pulley so it would fit in the designated space with the belt spacing correct per Johnson. A fun afternoon!
Discussion Starter · #5 ·
Here I thought the pump powered off of the generator pulley......learned something new.
I was thinking of taking one belt off of the triple pto pulley and using a direct drive to the pump. I thought two pto belts would drive plenty of power to a mower etc.
Any thoughts?
Any thoughts?
That is exactly how my 1250 was set up when I had a Johnson loader on it.
Twin pulley on the starter generator and a short belt to the loader pump. Worked well too.
When I switched the loader to a HT-23 I didn't have that option, since there isn't a starter generator. It's now powered from the pulley on the engine shaft as described by LP Bolens
Discussion Starter · #7 ·
Any idea where I could get a double pulley for the 1250?
You can ask Fred aka Deerlope if he has one to sell. He has the 1250 that I had the loader on. He may still have the pulley. He restored the tractor without a loader. Not sure if it's still on it or if he removed it a put the single pulley back. Either way he can measure it and let you know what to get. Pm him, he is a member here.
I am not sue if the pulley is still on it but it should be. The building that the tractor is stored in has a lot of snow in front of the door right now. If you will remind me in a few weeks I can get the size for you. Trying to shovel the snow away won't do because it is frozen.
Discussion Starter · #10 ·
I understand what you mean by all the frozen snow....it's crazy.
Does anyone know of a place you could order a pulley from?
1 - 11 of 11 Posts
