1 - 8 of 8 Posts
I currently have a 1969 1250, I sort of got it for nothing a few years ago in need of some repairs. I've since replaced all 4 tires, the fuel tank, battery, and am in the process of fixing several broken springs and levers for the PTO.
I used a buddies machine, a newer Ford, with a rear tiller on it. I'm pretty much sold on the rear tiller idea and want one for my 1250.
What are my options for a tiller?
Does it have to be for a Bolens?
How wide of a tiller can this machine power?
Will attachments from other machines work?
(If I found a tiller off say a Jacobsen or Cub Cadet would it work?)
You would have to make sure that the PTO turned in the proper direction for it for one thing ,Cub Cadet does not.
Discussion Starter · #5 ·
The key here is FIND.
Every one I've run across in the past was for sale for more than I could afford.
I don't mind doing some fix up if I found one a right price.
Besides, what are the chances of finding one worth fixing after 40+ years?
They are still around. They are pretty durable tillers and usually dont break. Most cases all you need are a couple new oil seals and your good to go.
Check CL and ebay, they pop up all the time
Discussion Starter · #8 ·
Jason4567 said:
yardion, where are you located? I know of a couple in MA for sale.
Jason
I'm roughly 300 miles from MA, on the far side of NJ. Too far to just drive up and take a look.
Bolens as a whole here seem a bit scarce, at least in my immediate area. Most have never seen one here.
I've only seen a few others in use, and they were tube frames not large frame models.
I did find a tiller that was on a tube frame but it's narrow, narrower than a plain old walk behind tiller. I'd be all day tilling up a 1/4 or 1/2 acre plot.
1 - 8 of 8 Posts
