1 - 15 of 15 Posts
I just bought this 1600 Eliminator got it home and found a couple issues I already have a 1400 gear, but this is a 1600 Hydro. They had the breather tubes on outside holes of air cleaner but they didn't fit right so 1 of my questions is shouldn't breather tubes be going from middle of air cleaner to outside? Second question is the carb looks funny and was leaking out while running I have taken pic of carb and something looks missing but I can't tell from the diagram what it is. Thanks in Advance for help
Derek
Derek
looks like its for the high speed needle screw and spring
cheers
8tyman8
Discussion Starter · #4 ·
took pic to guy at parts house he didn't know if it was missing anything? anyone have this same briggs motor?
Bob's Lawn and Garden LLC
The only thing that looks missing to me is the fuel solenoid.Is there a wire laying over there not hooked to anything?
i thought thats only on newer stuff thats like the late 90s the briggs appears to be from around the 80s
Discussion Starter · #8 ·
there is a wire taped up that hasn't been used in who knows how long, When I start it fuel is just dumping out of this hole and it wasn't doing this when I picked it up, I mean I had a puddle withing 30 secs of motor running.... thoughts, suggestions would be greatly appreciated What is that fuel solenoid purpose and did I just miss it leaking?
Discussion Starter · #9 ·
OK called shop I found a part number for a plug that is no longer available anyone by chance know the size of said plug?
Whats the part number and i will see if i have the plug here as i have alot of nos briggs parts.
I found the part from somewhere back east and ordered it it was about 10 pages deep on google lol
the part is 397882, I wish I had dimensions so I could throw something in there until actual part shows
Discussion Starter · #13 ·
I got a bolt and put it in, also night before I sprayed carb good with carb cleaner, I ran it today ran good. I am checking oil to make sure no gas is dumping into crankcase. New Problem: I shut off electric PTO and the went to restart it and nothing? Looked through the online service manuals we have and couldn't find manuals for Eliminators?
Discussion Starter · #14 ·
Update:I let it cool down for a couple hours and behold PTO worked again I have seen this with a lot of failing electrical parts and after mowing for 30 min I shut it off and tried to restart it and it did but took about 10 seconds, so is that Field Coil?
If this is a Briggs and Stratton engine you can go to their website and download the parts manual. You'll need the numbers off of your engine to get the correct one. I picked up Eliminator Hydro 1668 last week and did just that.
1 - 15 of 15 Posts
