So I picked up a 41" rubber tarp strap at the hardware store to see what I could come up with as a homemade version - the strap was $6.00 including tax so if it fails to function I won't be too upset but I think it will serve the purpose. Of course some modification is required.
Since the end of the strap is bulkier where the hook goes through I cut the strap at the point where the strap started to become the same size - about 3/4" from the end of the rubber. A pair of tin snips cut the rubber nicely after I used the square to provide a nice straight edge at the end. Then I clamped the strap in place around the duct swivel where it would sit and marked where the strap would meet to join together flush. I removed the strap and marked it 1/4" shorter for a cut line so that when joined together the strap would have to stretch a bit so it would be a snug fit on the duct swivel.
The resulting piece was 21" long and I marked two hole locations 1/2" from each end and 1/4" in from the edge where two 1/16" diameter holes were drilled in the rubber. Then I grabbed my roll of 18 gauge mechanics wire that i keep on hand.
