1 - 6 of 6 Posts
old member
I have a Bolens 1886-03 that I am trying to find the part number for the 2 pins that stick up through the fender pan and through the front seat mount brackets (there is a spring pin that holds the mounting brackets on). They are shown in the manuals but don't have a line # reference. They attach the front hinge of the seat and depending which hole they come through, allow the seat to be moved front or rear. The tractor I'm working on had bolts and a different seat and I want it to be original.
Premium Member
The pins that stick up on the fender are part of the fender....
old member
Discussion Starter · #3 ·
Mine has just the holes with no indication that there was anything there. I guess it will be bolts and nuts!.
old member
Discussion Starter · #6 ·
My 1886-02 just had the holes and nuts/bolts. There were pins there?
Yeah, the idea was you pull the spring pin and move the hinge to the other set of holes to move the seat front or rear and if you flip the hinge over it gives 2 more seat locations.
1 - 6 of 6 Posts
