1 - 5 of 5 Posts
As most of you know, I'm restoring my M/W -Bolens built Squire 6. It's the same tractor mechanically as the 600. I need to replace the shaft that the PTO Idler mounts on, someone cut mine off where the Idler mounts. I need the over all length of that shaft. I also need to know the location of the mounting hole that holds the Idler assembly on the shaft.
Thanks in Advance!!
Discussion Starter · #3 ·
Doc., Thanks and do you know what models share this same PTO setup? I might just buy a used one if I can find one.
Old, but not dead -- yet!
Do you know what models share this same PTO setup? I might just buy a used one if I can find one.
I'm not sure this will help you at all, but I'll try.
For the Bolens 600, the PTO control shaft is part # 1713369.
For the Bolens 650 & 750, the PTO control shaft is part # 1717347.
For the Bolens 800 & 900, the PTO control shaft is part # 1714589.
For the Bolens 853, the PTO control shaft is part # 1717324.
So, it appears the PTO shaft for the 600 is unique unless part # 1713369 was superceded by # 1717347. (Maybe someone with the Bolens Parts Price List can tell you.)
All of the tractor models listed above use a single belt for the PTO drive, and all use the same PTO idler pulley - part # 1713803.
If you try to fabricate a new shaft, the arm that the idler pulley bolts to will have to be the correct length, and welded in the correct position relative to the roll pin holes, so that the PTO lever functions correctly.
Bob's Lawn and Garden LLC
Bruce, I took a look and the 1713369 was not superceded by anything
Brian, if i can get a min i will look and see what the lenght is fro a 600 i have here for parts.
1 - 5 of 5 Posts
