1 - 5 of 5 Posts
i had the same problem this spring on my g14. I replaced the oil seal that goes inside the wheel hub and seals between the axle shaft and the wheel hub
http://gardentractortalk.com/forums/files/file/1334-bolens-1055-g10/
page 6 items 5 oil seal 1185295 and maybe item 77 oil seal 1185426. You can cross reference these number here http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
http://gardentractortalk.com/forums/files/file/2967-bolens-med-tube-frame-service-manual-552875-1/
page 3-6 figure 2
make sure to follow these directions when installing the seal so you dont tear the inner seal lip on the threads and splines. Possibly could use a cut pop can rolled up as a sleeve. watch out for sharp edges and use plenty of grease.
may not apply to your particular rear end http://gardentractortalk.com/forums/files/file/2739-bolens-rear-axle-end-play-adjustment/
edit, my leak had oil running out the end and onto the wheel rim, and then spin for a big mess.
1 - 5 of 5 Posts
